Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 10-07-2007, 01:25 PM
Panama2122 Panama2122 is offline
1996 Mercury Mystique Engine Replacement
I have a 1996 Mercury Mystique 2.5 24 valve Duratec with a broken cam and bad head. I feel it would be just as easy to replace the whole engine. Can someone tell me what years, makes, and models I can find this same engine?
Also, do you think it would be better just to change the head? I would have to drop the engine and transaxle if I wanted to do this, right?
Last question, does anyone have a 2.5 24 valve Duratec engine for sale? I am in Northeastern Pennsylvania.
Thanks in advance!
Old 10-08-2007, 07:52 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 1996 Mercury Mystique Engine Replacement
95-00 Contours/Mystiques used the 2.5L engine.
You may just want to swap a 3.0L. Its basically a direct swap.
You could just change the head without swapping pulling the motor, but your going to have a fun time trying to retime the motor with the small amount of room with the timing cover. There could be damage to the pistons as well as this isnt a non-interference engine.
Did you actually pull the valve cover and see that you have a broken cam? You would be the first person that I know of thats had this happen.
If your looking for engines for sale check out the contour.org classifieds.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
