Old 10-06-2007, 11:41 PM
stnapycnaf stnapycnaf is offline
Problems Problems ...
I have a 91 CRX HF with an A6 engine swap.
When I swapped I used my HF dizzy and put it on the A6 because it came without one.
It was timed correctly. Everything was fine.
Until today.
Driving around a curve my engine started bogging out heavily and it seemed to fall to using only 1 cylinder. So I shut it off. Popped the hood and discovered burn marks on my CAI by my pos. battery terminal. Mind you I don't have a battery tie-down. I changed the plugs thinking they fouled. The plugs came out covered in black soot [running rich?] but no other damage. I started the car, it cranks just fine, it just really didnt want to and it still only ran on one cylinder.
Symptoms:
Smoking [white/greyish] out of my exhaust
Very hot negative cable
Hard to start
Running on one cyl.
My thought is that the connection of the battery and CAI caused a short and fried my dizzy. Or its just old and decided to take a shit on me.
Any input would be great ... cause I need to go to school on Monday.
Thanks,
Justin
91 CRX HF
D16A6 Swap
Old 10-07-2007, 11:52 AM
Re: Problems Problems ...
UPDATE
I had my car towed home and removed the spark plugs and discovered that I wasn't burning the fuel. I checked the for spark and I do have it at the plugs. I then re-gapped the plugs correctly [they were a little close before]. I removed the dizzy cap and cleaned the terminals and reinstalled it. I cleaned off my battery terminals and snipped and primed both the pos. and negative wires.
Then I tried to start my car ... no crank. So now I'm charging my battery. My starter has sounded weak for a while now, so maybe its time to change that out. Good thing I have another one that is known to be working.
Any input or similar experience and guidance is appreciated and very welcome.
Thanks
91 CRX HF
D16A6 Swap
Old 10-07-2007, 12:01 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
did you check all your fuses?? couldve fried one when the battery touched the intake..get a little rubber protector or one of the velcro covers for your battery. i fried one of mine when my ground was loose on the alternator
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 10-07-2007, 02:11 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
x methinks you should check your compression... pry a long shot, but white smoke is indicative of two things... usually either your head gasket is blown, or you're SERIOUSLY not burning fuel. x
Old 10-07-2007, 08:02 PM
No dice with the starter. It won't crank at all.
HELP
91 CRX HF
D16A6 Swap
Old 10-08-2007, 11:17 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
i agree, check all your fuses.
Old 10-09-2007, 12:12 PM
I checked all of my fuses, they're fine. I did take the liberty of replacing my old corroded battery ground cable and now I'm cranking again. I'm still getting spark, its just not igniting. I figure I'm running really rich or my engine is flooded. I also discovered my #3 fuel injector has a slight leak at the fuel rail. I tried starting fluid to get it to kick, but it just caught for a split second and sputtered back to the starter cranking.
91 CRX HF
D16A6 Swap
Old 10-09-2007, 11:36 PM
check compression... that's my 2 cents. couldn't hurt anything to check it.
Old 10-10-2007, 01:14 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Screw cold air intakes to hell. You shorted something out, check your fuses/ wiring. Thank the lord that this didn't happen to you:
http://honda-tech.com/zerothread?id=2060211
Although a little longer and your car would have been kentucky fried chicken.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 10-10-2007, 09:11 PM
jeah i definately put some electrical tape around the area where the battery contacted the intake pipe.
I'm running a compression test tomorrow ... hopefully that turns out well
91 CRX HF
D16A6 Swap
Old 10-11-2007, 09:26 PM
so I ran a compression test ... and the results were awful.
As my car stands ... from the cylinder on the left to right [closest to dizzy over to the timing belt] I have:
60psi 30psi 90psi 60psi
Anybody care to enlighten me with the burden on my hands?
Thanks
*Also, my stepdad believes that my timing belt skipped [its loose] and the car was out of time when we towed it back home*
91 CRX HF
D16A6 Swap
Old 10-11-2007, 10:24 PM
Nick Gautreau's Avatar
Nick Gautreau Nick Gautreau is offline
Send a message via MSN to Nick Gautreau Send a message via Yahoo to Nick Gautreau
Suggestion... Get it rebuilt!
(or even better yet, get a cheap SOHC 1.5L from the junkyard and put that in as a temp solution. Thats what I did with mine. (Not this Civic... I used to have a 89CivicHB))
Originally Posted by Dr0pZ0n3
I just think it's funny to pull up to a redlight in a beaten 4dr against some oldie in his "muscle" car... rev the lil tiny snowblower motor against his loud ass V8, then leave him sitting there when the light turns green...
1990 Honda Civic DX - Getting custom!! Needs battery
I need parts for my car. Please contact me via PM if you have anything to get rid of
Old 10-11-2007, 10:31 PM
well ... if it came to the point where I can't fix this without removing and replacing my engine ... I was just going to toss in another HF engine [or something similar] and build this for either turbo or mini-me
I just really dont have the time right now ... I need my car to go ... school is getting really near.
91 CRX HF
D16A6 Swap
Old 10-11-2007, 11:36 PM
Yeah that is a possibility. If your timing is off then that will yield you low compression results since the valves are opening and closing at the wrong times. Check your TDC position out at least; I'd start from there before getting a new motor, especially if it was running before.
Old 10-12-2007, 12:03 AM
check the timing belt for if it's broken, check the overall valve timing, if it jumped while it was running, it may have bent valves or put a hole in a piston... latter is less-than-likely, since you're getting any compression at all...
also, if you're throwing white smoke, it's probably either oil or water leaking into the combustion chambers... check/replace your head gasket.
