Old 10-06-2007, 11:12 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
replacing e brake equalizer (95 jimmy sls)
hey guys i am just looking for some info on on how to replace the e brake equalizer correctly as the truck i am working on the old one rusted in half and broke
thanks guys
Old 10-07-2007, 09:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: replacing e brake equalizer (95 jimmy sls)
If that rusted have a good look at all of the other steel lines and fitting.
The big problem may be getting the line and fittings lose.
Good brake line wrenches will help.
If ABS brakes and you let air get into the ABS system it requires a ABS capable scanner and a couple of combination valve depressors to bleed the system.
Good luck
MT
MT
Old 10-07-2007, 09:34 AM
DelCoch's Avatar
DelCoch DelCoch is offline
What do you mean by e brake? Are you talking about the emergency brake??
Old 10-07-2007, 10:03 AM
MT-2500's Avatar
AF - Advisor
If the emergency brake disregard my info on the brake repair.
But it would still be a good idea to check all steel brake lines in the rear area.
MT
MT
Old 10-07-2007, 08:26 PM
old_master's Avatar
Advisor/Moderator
To replace the park brake equalizer, the upper return springs must be removed first, then you can slide the equalizer bar in place and reinstall the springs.
