Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-06-2007, 04:31 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Brake light fades in..
I just noticed my car doing this the other morning. The brake light wont completely go off. Its really only noticable at night but the light stays barely lite. But the higher I rev the car the brighter it gets. So at idle its barely noticeable but at 5k its pretty bright. Checked brake fluid first and its completely full. Also disconnected my ebrake grounding wire thinking the switch maybe be bad or the turbo timer might be screwing with it since it hooks into that wire as a safety feature. Still does the same thing. Maybe the sensor in the brake resorvoir could be going bad. I did resently change to high performance brake fluid.
This is the fluid I put in.
http://www.hrpworld.com/index.cfm?fo...action=product
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-06-2007, 10:01 PM
Holset powered 420a
Re: Brake light fades in..
Looked into it some more and it seems it fades in more the more I get on the throttle... I am totally lost on this one.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-06-2007, 10:16 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
High performance brake fluid? Geezus what else are they going to come out with. Switch back to some regular stuff and see if the light goes back out.
95 Talon TSI AWD
97 Eclipse GST
Old 10-07-2007, 07:50 AM
Holset powered 420a
Damn that is such a PITA to do. I dont really have alot of time right now so I might be able to get to it. It doesn't cause any problems I was just curious. I might go unplug the sensor on the resorvoir to see if that stops it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-07-2007, 12:39 PM
That will most likely make the light stay on constantly, making it think its out of that high-performance brake fluid you speak of.
95 Talon TSI AWD
97 Eclipse GST
Old 10-07-2007, 06:45 PM
kjewer1 kjewer1 is offline
AF - Advisor
Check your alternator voltage at idle.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-07-2007, 09:16 PM
Holset powered 420a
Voltage is around 13.5 at idle. I think its usally around 12.8 once the car is fully warmed up though.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-07-2007, 11:45 PM
AF - Advisor
It should stay up at 13.5 all the time when running. It often drops at WOT/high rpm, but that's it. I only ask because weird dash light behavior is the classis sign that the alternator is in the process of crapping out.
Kevin Jewer
Old 10-08-2007, 08:59 AM
Holset powered 420a
Ok, thanks for the heads up. I will keep an eye on the voltage. My turbo timer will display it. So Kevin, you dont think it could be the different brake fluid messing with the sensor?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-08-2007, 11:21 PM
AF - Advisor
I would say no.
Kevin Jewer
Old 10-08-2007, 11:34 PM
Doesn't that usually affect all of the dash lights, and not just a single light? That's how I always understood it.
95 Talon TSI AWD
97 Eclipse GST
