Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 10-06-2007, 04:12 PM
eggbirtt eggbirtt is offline
91 3.1 Will start if I give it gas but won't idle
If I give it gas, it will start. It will not idle though. It has a brand new fuel pump, filter, lines etc. I pulled it in the garage to replace the carpet, disconnected the battery, replaced the carpet and now it won't start nor stay running. Please help. Thanks in advance.
Old 10-06-2007, 06:42 PM
anomaly_va_1976 anomaly_va_1976 is offline
Re: 91 3.1 Will start if I give it gas but won't idle
My 93 had a similar problem.... The IAC valve was stuck... are there any codes set by the ECM?
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
Old 01-11-2008, 01:55 AM
Just a thought.... the ECM could've gotten zapped when you reconnected the battery... my 93 had similar problems and turned out the ECM was bad, loading the engine up with fuel at idle.
Old 01-26-2008, 05:31 PM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
Idle Air Controller... about a 60.00 dollor part that takes less the ten minutes to change on a Beretta...
and there is a idle relearn procedure it MUST go through to run right again...
Removed by Moderator
Old 04-20-2008, 01:42 PM
tomtom123 tomtom123 is offline
check the TPS
