Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-05-2007, 11:18 PM
mydelsol mydelsol is offline
No Light!
I have a 90 tsi awd and my fog lights simply won't turn on. Whether my headlights are on or off, my fog lights just dont turn on. What should I do? I have tried to remove them to inspect them, but the screws just stripped, its as if the screws are plastic. Thanks
1993 del sol s
1990 Eagle Talon Tsi Awd
Old 10-05-2007, 11:25 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: No Light!
I believe there is a "FOG" fuse in the fusebox under the hood. It might be a relay though, check it out anyway. And, as stupid as it may seem, is your foglight switch on?
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 10-06-2007, 12:26 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: No Light!
I bet the bulbs are dead.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-06-2007, 03:02 AM
Re: No Light!
Hmm, I will take another look at the fuse. I have tried three different fog light switches. I dont know if they worked, but I tried them. I stripped the screws trying to take them out, should I just try and drill them out? That would be the only way to determine if the bulbs are out correct? Thanks
1993 del sol s
Old 10-06-2007, 12:15 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: No Light!
yea drill the out and put new screws in. Just be careful not to screw it up.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-06-2007, 09:02 PM
Re: No Light!
I checked the fuses under the hood and they looked good to me. I guess I will try to drill out the screws. Thanks
1993 del sol s
