Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-05-2007, 10:49 PM
jandj1999 jandj1999 is offline
'98 3.2 camshaft timing
Bought a '98 Rodeo with a bad crank(3.2 DOHC v.i.n code W.Engine had been partially disassembled.After rebuild and reassembly.Engine runs as if slow on timing and shows a code po300 (intermittent miss fire).Repair manual (Haynes) only showed a drawing not an actually camshaft setup.NOT THE TIMING BELT ALIGNMENT MARKS.Checked all the obvious possibilities.Need an actual picture of the camshaft marks and the idler shaft being aligned OR someone who is familiar with this camshaft set-up....Any advice or help would be greatly appreciated.
