Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-05-2007, 10:47 PM
MiKE5050 MiKE5050 is offline
Noise when clutch isn't pressed.
Hey guys. I drive a 2000 Mitsubishi Eclipse and I am hearing a weird noise. To describe it, it sort of sounds like a continuous clicking or ticking when the clutch is released. When i press the clutch, the noise stops. Any ideas? Suggestions to what I can do about it? Thanks.
Old 10-06-2007, 01:55 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Noise when clutch isn't pressed.
Throw out bearing (TOB) is rattling...nothing you can do about it besides replace it, and even then it will start to do it again...nothing is hurt, deal with it like the rest of us...sorry
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 10-06-2007, 11:20 PM
thanks alot. your advice is greatly appreciated.
Old 10-07-2007, 06:24 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Actually, isn't a rattling TOB a sign of it going bad? The reason I thought this is because I had one that rattled and I replaced it when I put my new tranny in and it didn't rattle after that...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-07-2007, 11:03 PM
rodbls's Avatar
well, yes and no. The thing is that mine rattled too, i replaced my clutch and TOB and about 1000 or so miles later it started to rattle again...so even the new OEM TOB's or aftermarket ones still rattle after a short while. I dont think there can be any damage done to the tranny or clutch because of a noisy TOB, other than the fact that it is probably going to be fused to your flywheel like mine was, resulting in you having to either destroy the flywheel or pressure plate to get it off should you decide to replace something in there. It sucks ass, and is annoying as hell, but like I said, I dont think any damage is being done.
Old 10-08-2007, 06:26 AM
Ahhh wait wait, ya know what I just thought about... Your supposed to put grease on the TOB edge that touches another surface to prevent it from being damaged AND to eliminate TOB rattle... Did you do that when you replaced your TOB? If not, maybe that is why it is still rattling... I bet that's why mine doesn't rattle this time around...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-08-2007, 09:12 AM
808drifter 808drifter is offline
Wouldn't mater in this case.
This is a well known problem with this car.
Top 2 noise calling problems with this car are, TOB rattle and lifter tick.
Old 10-09-2007, 11:40 PM
really? that's pretty interesting. so basically, so i put grease on the TOB edge? because if it does stop the rattling, i'll definately try it. Thanks for your advice guys.
Old 10-10-2007, 02:23 AM
rodbls's Avatar
Not sure if you are aware of this or not...but in order to get to your TOB you need to drop your trans (Which is the biggest mother fucker in this car). Also, as stated by me earlier, you will probably not be able to disengage your TOB from your pressure plate to even get it out....so you are probably up shit crick on this one.
PS. Unless you REALLY know what you are doing you should NOT attempt to replace the clutch on your own. I took mine to a shop that works on FWD cars specifically and it still took them 2 days to get the job done because it is such a pain in the ass.
Old 10-10-2007, 09:15 PM
yeaaah thanks for that man. and the whole clutch thing, i can wonder how much of a bitch it was to change it. are you running on a performance clutch? because when i decide to change it, i'm not sure whether my best bet is a OEM clutch or a performance clutch. i was told that the clutch is harder to engage with performance clutches.
Old 10-11-2007, 01:15 AM
rodbls's Avatar
I have a SPEC Stage 2+ Clutch kit with a Fidanza Lightened flywheel. It drives OOOHHH soo much better than the stock one did. It grabs nice and early, and hard, but not so hard that there is no friction zone. No slip at all when I smash through gears, it grabs hard every time no matter how hard I'm driving. It does make a loud humming noise sometimes though when it's in the friction zone...not sure why, but I'm over it.
