Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-05-2007, 11:09 PM
boarder4life boarder4life is offline
AWD Help
I bought a 93 Talon. The timing belt broke on the guy who owned it before me. thats why he sold it. its AWD, and i was dissasembling the engine and without thinking about it, i took of the front tires. they were up in the air, on jack stands, and they spun a few times with back tires on the ground. it wasnt until later when i read the sticker on the door that said it has a viscous coupling and limited slip diff. in the rear end, and how I CANT ROTATE ANY TIRES WHILE THEY ARE IN THE AIR. it was in gear at the time. did i do any damage to anything? and what do i have to do to get it set right?
Old 10-06-2007, 01:37 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: AWD Help
i guess i dont understand what you are asking... did you start the car? or move the tires by hand? (but w/o a timming belt, the motor wouldnt start) if you turned by hand, its fine! dont even worry about it, if you where dumb enough to crank the motor w/o a timming belt, the AWD is probably going to be added the the new Engine check list...
Old 10-06-2007, 01:39 PM
Re: AWD Help
i turned them by hand. its ok if i turn them by hand? just cant turn them in the air when shes running?
Old 10-06-2007, 02:05 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: AWD Help
I think you should be ok as long as you didn't move them a lot. That sticker is there more for towing.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-06-2007, 02:34 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: AWD Help
If I remember the sticker correctly (and I do ) it has to do with the rear wheels only. Basically, the warning is about the LSD in the rear end and how bad things will happen if you jack up one side while leaving the other on the ground, and then trying to start it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-06-2007, 03:13 PM
Re: AWD Help
awesome! thanks alot.
Old 10-06-2007, 04:12 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: AWD Help
By this, do you mean trying to start the vehicle moving? On a few occasions I've had the front end jacked up, and started the vehicle and nothing happened. But then again i never tried to put it in gear and go either. By side do you mean passenger and driver side, or front and back side? I'm just misunderstanding i think.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-06-2007, 04:29 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: AWD Help
You can't tow it with 2 wheels on the ground is what i think he meant. It makes no difference if you jack the front or rear up and start the car. Just don't move it around with 2 wheel on the ground.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
