Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-05-2007, 08:15 PM
aeflower9 aeflower9 is offline
Post 1.8L Oil DRIP
i just bought the car and i notice a little bit of oil on the ground. i checked the valve cover and no leaks there. the leak is coming from the back of the engine under the intake manifold on the driver side. what could cause that would it be the rear main seal. If anyone knows i would be very thankful and also if you know what it is would it be very difficult to change or expensive thanks a lot
Old 10-05-2007, 10:36 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: 1.8L Oil DRIP
The rear main seal is between the engine and transmission. It seals up the rear end of the crankshaft, hence the name. Possible head gasket from where you're describing but I'm not really sure. An oil leak can look like its coming from somewhere when it really isn't. I am not too familiar with the 1.8.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
