Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-05-2007, 09:08 PM
DLR8 DLR8 is offline
95 2.0 Severe engine miss
Hello everyone ... I am having an on going problem with a 95 contour 2.0 problem started with a random shifting in an out of gears, I noticed when this happened the engine would be missing when I put it in neutral.. Now it has gotten to the point where any time you apply throttle the engine begins to miss, idle seems to be fine. I have looked through this site and have not found the exact problem so I decided to post it... Any help would be appreciated since the car is right now not driveable.
Parts replaced
TPC
Plugs and wires
Coil
No change, no engine light on
Old 10-06-2007, 12:02 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 95 2.0 Severe engine miss
Run a search on contour.org.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-06-2007, 12:21 PM
2001jettavr6 2001jettavr6 is offline
Have your fuel injectors cleaned, and change out your fuel filter. That might help.
Old 10-13-2007, 05:08 PM
Thanks for the replies, I will check fuel pressure when I get the chance. I hate that this car has to sit due to the fact that it has less than 50k miles on it.. had it to the dealer when the problem started, they recommended a 4k transmission because of the shifting problem.. the shifting problem is a result of the missing .. it only shifts bad when the car is missing... I was hoping someone else had encountered this problem and could point me in a direction.
Thanks
Dave
Old 10-14-2007, 07:08 PM
Davescort97 Davescort97 is offline
Escort guy
If it is still missing you might try new ignition wires to the plugs. There is nothing wrong with your transmission. It is supposed to downshift when there isn't enough power in the current gear. Seems that the plug wires start shorting out whenever you need power the most---under acceleration.
Old 10-15-2007, 08:35 AM
wafrederick wafrederick is offline
Banned
Do a compression check too.The 2.0 is known for bad headgaskets and that will cause a miss too.Try taking it to someone that knows Mazdas,the 2.0 is Mazda engine.
Old 10-17-2007, 12:11 PM
bonder bonder is offline
I'm going through the same problem, I think -- bad shifts when throttling. I am out of warranty so I haven't been dealing with a Ford dealership but a local service garage. Anyway, after a lot of transmission rebuild the problem came back, and it appears that it's related to cracking of the wiring in the main sensor wiring harness and injector wiring harness. Manual tape-up of this wiring doesn't work very long, as you might guess.
I found this recall: http://www.contour.org/FAQ/recall/99M03/
I also have these part numbers:
Main Sensor Wiring Harness
F5RZ1EA581S6A
Injector Wiring Harness
F5RZ9D93S6A
However, I can't even find these used on the entire interweb so far.
If I can't find these my only recourse is to buy new parts, which are in stock but will apparently cost $2000.
Ugh!
