Old 10-05-2007, 07:57 PM
DDB_99 DDB_99 is offline
EGR Issue/94 Safari
I replaced the EGR valve a few months ago. Recently the dreaded "check engine light" came on and the engine began running rough. The code was 32 EGR and now there is a very strong gas smell. Solutions?
Fortunately I'm not dependent on the van right now. Thanks for any ideas.
Old 10-05-2007, 08:20 PM
CD Smalley CD Smalley is offline
Re: EGR Issue/94 Safari
Well I have to ask.... Did you buy a AC-Delco part? If not, I would suspect the EGR valve again.
Are you getting any other codes?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-08-2007, 06:26 PM
I didn't buy an AC-Delco part and I didn't have any other codes.
I managed to remove the valve today (my hands are too freaking big). There was a small carbon deposit that had forced the valve to stick. I removed the carbon and the valve appeared to function as its supposed to. I reinstalled it and the van is running fine now. I wonder what caused that carbon build up.
Thanks for the help.
Old 10-08-2007, 06:48 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
[quote=DDB_99 There was a small carbon deposit that had forced the valve to stick. I removed the carbon and the valve appeared to function as its supposed to. I reinstalled it and the van is running fine now. I wonder what caused that carbon build up.
Thanks for the help.[/QUOTE]
The 4.3 engine is notorious for carbon build up particulary if you use it for short trips mostly, then when you do a high speed long run the carbon will break loose fouling the EGR. Two things you can do 1: get a screened gasket for the EGR valve to catch the carbon particles, I got mine at NAPA, and 2: run a good brand of 87 octane gas with detegents. I swear by Chevron or Texaco with the additative Techron, keeps mine clean. You can also buy Techron at the auto parts store as an additative to your fuel. Two tankfulls will make a notiable difference.
Old 10-08-2007, 08:53 PM
Screened gasket eh? That sounds like a good idea. I don't have many Chevron or Texaco stations nearby but I'll look around.
