P0753 - shift solenoid electrical
Ran the truck today. Felt like it was having trouble accelerating from a stop. Pulled code P0753 with the scan tool. Any insight? I'll search now. Thanks for any information! P0753 = shifter solenoid circuit A electrical
As an aside, I also had 2 O2 sensor codes. No activity from the front 2 sensors which I changed out a little while ago. I found the bank 1 harness resting on the exhaust because the O2 sensor bracket to which the bank 2 harness is connected is hanging free. I ziptied it up and cleared the codes and they didn't come back.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K Last edited by FL 3.2L; 10-05-2007 at 08:10 PM. |
Re: P0753 - shift solenoid electrical
http://www.automotiveforums.com/vbul...shift+solenoid
My answer is probably here. Initial post describes my symptoms exactly. Looks like the front pan needs to come down. Here is some discussion from a Tacoma site. Seems like it would apply here: http://www.tankota.net/repair/Repair...a/cip0753p.pdf
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K Last edited by FL 3.2L; 10-05-2007 at 08:57 PM. |
I wonder if I created the code by pulling on the tranny wiring harness...
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K '96 Jetta 249K '97 TJ 156K '02 VW Cabrio 70K '03 E46 107K |
Yup. Pretty sure I did it. The daughter says it didn't drive anything like that until I got ahold of it. Sorry for wasting your click!
Looks like the solenoid A is in the main case. These diagrams might help someone in the future.
1994 Acura Integra LS---212K+ 1998 Isuzu Rodeo S 3.2L 2WD---176K+ |
Thanks a lot for posting that. Little more detailed than my Haynes I'll bet.
Problem fixed. I removed the ziptie and the code disappeared and first gear works properly. Now I know what it feels like when the torque converter fails to lock up in first. I guess that's the job of the Circuit A solenoid.
Im getting the same error message, I was going to replace the solenoid but couldnt get the pin out. But my question is , what wires you checked or where was the harness that was pulled? I recently had mine aligned and the day afther the problem started... Or anything else I can check?
Or if i do have to go back to the solenoid does any one have the resistance, ohms, or anything else i can check while its two wires are exposed? Thanks all
1997 Honda Passport 3.2 SOHC 188,000 + ... |
Driver's side of the tranny up high. Go under there when the truck is cool and you can trace the O2 wiring to a connector and bracket. Moving that collection of wires affects the tranny harness, it seems.
i have a 2000 passport with tranny issues the only way i can drive it is by taking off with the winter mode on cause if i put it in drive is like puttingg it
in park nothing happends i get a code of p0756 help please anyone |
