Old 10-05-2007, 04:45 PM
nichols45 nichols45 is offline
Modulating Vlv Location
I have a 90 Suburban auto tran that will not shift out of 1st. I was told to change out the modulating valve first and see if that fixes it. I looked all over the tarn and have not found the valve and looked at numerous manuals with no luck. I have't pulled the pan yet so it might be in their. ANy suggestions?
Old 10-06-2007, 08:37 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Re: Modulating Vlv Location
I think the valve you are reffering to is simply mounted on the side of the transmission. No need to drop the pan.
Old 10-07-2007, 05:28 PM
abaird abaird is offline
700R4's don't have a modulating valve
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 10-08-2007, 10:27 PM
This trans is a 700R4. Any suggestions on what to check to see why it will not shift out of 1st?
Old 10-09-2007, 12:08 AM
2000CAYukon 2000CAYukon is offline
Does Reverse work at all?
Does it stay in 1st and not shift at all or does it shift from 1st to Neutral (i.e. slips)?
//2000CAYukon
Old 10-09-2007, 12:30 AM
I runs in reverse and will not shift out of 1st. I have tried to downshift to 1st and when I get fast enough to shift into 2nd manually shift to 2nd but it will not shift. I have not had any warning signs of tranny problems. Drove it on the highway and parked it overnight and the next day it would not shift. This is tanny is only 5 years old.
Old 10-09-2007, 01:42 AM
Looking at my factory manual for 700R4 not upshifting out of 1st:
- Governor Assembly
- 1-2 Shift valve sticking
- 2-4 Servo Assembly
- 2-4 Band Assembly
//2000CAYukon
