Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 10-05-2007, 04:38 PM
unisphere unisphere is offline
parking brake/fluid leak
hi -
im new and pretty ignorant about mechanics, but i'm giving it a go by trying to repair an '89 ranger. relatively minor things mostly.
my first question: if i disconnect the parking brake line, should i experience a brake fluid leak when i use the brake (or any of the brakes on the truck, for that matter)?
i had the line disconnected to work on the rear suspension (shackle brackets/leaf springs) and then had to move the truck. i started it - accidentally depressing/releasing the parking brake - and moved the truck (obviously using the front/rear brakes as well). when i went to do more work the next day, there was a puddle underneath my gas tank. its not gas, and im pretty sure its brake fluid. does this seem consistent with anything ive done? or do i just have a new leak in a brake line?
thanks
e
edit: after looking more closely, it looks like i have a leak in the brake line (caused by something separate from my disconnecting the parking brake). unfortunately, its right in an inaccessible place - somewhere between the front of the gas tank and the middle of the tank where the line surfaces again. i'll go to the library, but does anyone have a brake line diagram? i'm wondering if theres a joint in the area i cant see that has sprung a leak, or whether i should disconnect the line at the closest visable joints.
Old 10-06-2007, 01:46 AM
Davescort97 Davescort97 is offline
Escort guy
Re: parking brake/fluid leak
The parking brake is a cable so I don't think that would cause a fluid leak. There is a flexible brake line (hose) between the frame and the rear axle. It goes into a block that feeds both the rear brakes by steel lines. I thilnk the flex hose brake line may have a hole in it. Check your master cylinder. Is the flulid level low? IF you press on the brake pedal will it do it again? Will it leak?
Old 10-06-2007, 04:52 PM
i solved the problem by replacing the brake line that runs aling the frame to the rear axle. it was rusted out.
thanks
