Old 10-05-2007, 03:27 PM
Eaglelong76 Eaglelong76 is offline
Alero Brake Problem
I have a 2000 Olds Alero w/ a 3.4L V6. When I push the brake pedal down, I hear air noise. I was going to bleed the brakes first, and then replace the master cylinder. Am I on the right track?
Old 10-05-2007, 03:48 PM
inafogg inafogg is offline
Re: Alero Brake Problem
hello, how do breaks feel/work ok?check the brake booster for vacuum leak
possible check valve in booster.
Old 10-05-2007, 03:49 PM
The brakes barely work. Where is the brake booster located?
Old 10-05-2007, 05:11 PM
they hardly work.like there's no power assist??brake booster is mounted on firewall in front of driver in the engine compartment.check valve is the plastic valve that the vacuum hose connects to on booster.see if u have vacuum there.if not check vacuum sorce at intake manifold.with engine running unplug vacuum hose engine should stall if not you dont have
enough vacuum.
Old 10-05-2007, 05:28 PM
The brake pedal pushes all the way to the floor and does not stop the car.
The engine almost stalls when you push the brake pedal to the floor.
I really appreciate all of your input.
Old 10-05-2007, 06:41 PM
if you have checked the fluid level & its ok & you have'nt done anything to the brakes. it sounds like the master cylinder is bad like you were thinking in the first place.good luck!!
