Old 10-05-2007, 02:05 PM
tpliquid tpliquid is offline
Send a message via AIM to tpliquid
dont you hate it when u sanded too much paint off
sigh, i had to repaint this damn car 2 times already.
i sanded down the clear coat smooth. then i polished the clear coat and black paint off. now its showing primer.
it was going good until that happened. dont you guys hate it when that happens?
friends let friends drive benzes
Old 10-05-2007, 02:14 PM
freakray freakray is offline
AF Modelrater
Re: dont you hate it when u sanded too much paint off
Why didn't you stop when you got through the clear into the black paint?
AF User Guidelines
Old 10-05-2007, 02:16 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Freakin hate that.
It's why stopped using micromesh. I find that there are better ways now....
PHOTOBUCKET SUCKS
Old 10-05-2007, 02:26 PM
Didymus Didymus is offline
Which are...????
Actually, I agree. Tamiya's compounds are faster and produce better results. The "Coarse" is not really very coarse, but it's sufficient to take out orange peel. (What other reason is there for sanding a base coat or a clear coat?) And you get a brilliant shine with the Finish grade. It's too expensive, but it sure is good.
That said, burn-through is the result of removing paint; the method doesn't really matter so long as you aren't using something that accidentally scrapes edges and high spots. The only ways to actually PREVENT burn-through are to a) apply more paint and b) protect edges with masking tape.
Diddy
Old 10-05-2007, 02:29 PM
i think i need apply more clear on it. i did not notice paint coming off until i finished using compound on the paint.
i guess i sanded down to the very last layer of the clear and the compound ate it all up.
Old 10-05-2007, 05:04 PM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
Yes!!!
I stopped doing that because it's just soo annoying
Now I only use Finisher's Compound, the "hard" one even polishes out some imperfections and the other two are just to bring the shine back, works great as long as you don't have to much orange peel!!
Old 10-06-2007, 04:42 AM
chato de shamrock chato de shamrock is offline
It happened to the model I finally finished last week. I gently, and i do mean gently, sanded and somehow managed to remove paint. I had to paint it over. Once that was done I applied some decals, CF decal in trunk and hood included. That came out nicely and i proceeded to clear coat it followed by painting the window trims in black. I masked around the windows and painted. After all this was done i peeled off the masking tape (made by Tamiya) and wouldnt you believe the masking tape pulled some of the CF decal off the trunk.
HEY!!! HEY!!!
Old 10-06-2007, 11:28 AM
A shame and a pity. I'd hate that even more than sanding too much paint off.
I've never even thought about it; always just assumed that "naked" decals are too delicate to be masked, especially with tape.
Diddy
