Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-05-2007, 01:02 PM
jeffharley jeffharley is offline
Send a message via AIM to jeffharley
95 Jimmy rear diff.
I trying to find out if there is a drain/fill plug for the rear differential. This is a 95 4 door 4x4 auto 4.3 I've looked and tried to find one to no avail, and trying to stay away from removing the cover to do this, as I can't see a way to fill it after I get the cover off and then replace it. Thanks in advance
Old 10-05-2007, 02:55 PM
maxwedge maxwedge is offline
A990 racer
Re: 95 Jimmy rear diff.
There is a recessed pipe plug r/s of housing above the horizontal casting.
Old 10-15-2007, 03:45 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Ayup...there's a fill plug where maxwedge points, but no drain plug. If you had to, you could suck the old oil out with a long tube and pump, but you'll be leaving all the attached metal shavings to the magnet on the inside of the cover.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
