Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-05-2007, 10:20 AM
ABigWeaney ABigWeaney is offline
building a head
OK i have a 92 tsi fwd and i am looking for 300-400 hp
tell me if this stuff is any good or direct me to some better parts. my budget is about 2000.
hks 272 cams or Brian crower stage 3 cams
arp studs
revised lifters
topline rocker arms
manley springs with titanium retainers
manley valve locks
ferrea valve stem seals
manganeese-bronze valve guides
ferrea 6000 series valves
Old 10-05-2007, 10:43 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: building a head
Largely unneeded. Go with BC, Comp, or FP cams as they are cheaper than HKS's. Depending on the grind, you may or may not need adjustable cam gears (I would suggets FP2's, compatible with stock springs/retainers, cheapest, and they dont need adjustable cam gearrs). You dont need new valves, guides, rocker arms, or locks unless the old ones are defunct. Same goes for the lifters, I wouldnt waste the money unless they are ticking like mad. The ARP's are good though, as are the new valve seals (not necessarily Ferrea), and the springs/retainers are a pretty good idea as well, though also unneeded.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-05-2007, 11:34 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: building a head
I highly recommend springs/retainers especially with new cams. Need the extra holding power, stockers will wear out quickly. Plus, the retainers are usually light weight, freeing up some power there. It all depends on how much you want to spend though.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-05-2007, 01:43 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: building a head
How many miles are on the car? If it's any more than 150k, I would say upgrade the head internals as well, that shit is already almost 16 years old.
95 Talon TSI AWD
97 Eclipse GST
Old 10-05-2007, 09:19 PM
Re: building a head
The motor is being rebuilt right now and i was looking for the stuff for the head. Yes i know it might not be needed but i would like to have as much new stuff as possible.The guides were cracked so i need different ones. Thanks
Old 10-06-2007, 03:41 AM
Thor06's Avatar
Jizzed In My Pants
Re: building a head
Since retainers arent part of the rotating mass, weight savings will only matter in the overall weight of the car, and whether or not you take a shit before the race will affect it more than that.
If you really want all that then that is fine, but whether you need it or not is debatable. I should also note there is some routine maintenance that is much more important than mods, be sure you take care of those first. Things include a valve job, making sure the head is straignt, and a timing belt job.
Old 10-07-2007, 05:18 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: building a head
Retainers are part of the reciprocating mass though, which can be looked at as just a really flat circle.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
