Old 10-05-2007, 07:23 AM
donaldh donaldh is offline
p0440 error
1997 cavalier
my code reader said that the evap system has a fault in numbered
p0440.
i know its in the evap system.
freeze frame says its in the following...fuel sys 2 cl-fault.
what does this mean and how or what do i fix to remove this error.
meter sys all of these below
fuel sys 1 ol
fuel sys 2 cl-fault
calc load 0.00
ect 197
stft b1 0.00
ltft b1 -6.25
map inhg 13.58
eng rpm 0
veh speed 0
this is what it reads.
hope someone can help.
Old 10-05-2007, 01:12 PM
rodfoster rodfoster is offline
Re: p0440 error
if i remember correctly, one of the repairs for this was to replace the "vent valve" it is an emissions valve near the gas tank- dealer item only, it's been like two years since i worked at the dealer but i think the part # is 15215729 about 30 bucks or so. i would check a little further before assuming anything
Old 10-05-2007, 05:57 PM
shakewell shakewell is offline
Re: p0440 error
The code you have is one of the least important ones so don't loase any sleep over it. The most common reason for a p0440 code to show up is not putting the gas cap back on or putting it on wrong. If the seal on the cap is bad you can also get this code.
Best bet - clear the code, see if/when it comes back. Go from there.
