Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-05-2007, 12:05 AM
Klownicle Klownicle is offline
New Alternator Installed, New Problem
I was haveing a low amperage issue on my 8 year old orignal hitachi alternator, so I opted out to replace it.
I bought a bosch alternator rebuild for 245$ at napa auto parts.
Everything is going smooth after the install of the alt, I go to napa about 2 hours later to return the alt core. I return the alt core, get in the car and crank it.
Car starts... My Battery and Brake light are on. They won't turn off.
Napa tested the battery, (still under warrenty at autozone gold duralast 925ca) and they said the battery was bad, could be why the bat light is on.
So I bring it to autozone to replace the battery, they tell me the battery is good but no signal from alternator.
I been driving all day on the battery, Im getting 12+ volts from my bat, so with the run around that I got. I just replaced the battery with one I had lying around. Still got the battery and brake light issue.
So its not the battery.
I've checked all the connections there all good. The light may flicker sometimes.
I've checked whatever fuses I think are related (the ones I can see). And there ok..
Did I get a bum bosch alternator? As far as I can tell the voltage on the postive post of the alternator is the same at the battery 12ish. It doesn't seem like the alt is putting out anything.
And how the hell do I get autozone to replace my soo called bad battery even thoe they say its good. Anyone with a "GOOD" battery tool shows the battery being bad. But again, I used a different battery and still had the bat and brake light.
Old 10-05-2007, 04:37 AM
boritz's Avatar
boritz boritz is offline
Re: New Alternator Installed, New Problem
If all connections are correct my bet is a dud alternator.
Here is a thread on similar pain that I went through: http://forum.planetisuzoo.com/viewtopic.php?t=13757
It describes some of the testing procedures.
Hope you fix it.
Old 10-05-2007, 07:07 AM
srpope80 srpope80 is offline
A good alternator on the Rodeo should be reading approx. 13.5-14 volts at the battery while idling. Easy way to test is get a cheap Voltmeter, and hold it to the terminals why your engine is idling.
Old 10-05-2007, 07:45 AM
Ramblin Fever Ramblin Fever is offline
They, Napa, sold you a bad alternator - should be covered under warranty.
It's possible the rebuilt by Bosch may not be as good as they used to be, I got mine over 4yrs ago. Maybe the quality has changed....I wouldn't be surprized.
Or, it could just be bad luck of the draw....but, it's the alternator, not your battery.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 10-05-2007, 09:40 AM
Well the replacement should arrive today around noon or tommorrow. And I should be able to get it installed.
I don't know where else to get a alternator, I had to special order this bosch.
Everyone else has cheap remanufactured ones. This bosch is a premium remanufactured.
Old 10-05-2007, 12:20 PM
95passport 95passport is offline
new around here...
did you install the alternator correctly and are you getting power to it?
otherwise seems like a bad one
Old 10-05-2007, 05:13 PM
FL 3.2L FL 3.2L is offline
That's a bummer. I'm sure you went the NAPA route to avoid this hassle. I had good luck with mine and recommend it frequently, but I guess no rebuild is 100% guaranteed to work. I had a bad rebuild out of the box from Advance, tried a new battery, had the same result with the new battery, and had to get a new alt. Four trips later the truck was running right again. Good luck.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 10-05-2007, 08:06 PM
The alternator was installed correctly. And as far as I know its getting power. The previous one was. Never in the two years owning this car have I had the battery light come on. I would assume it is getting power. Not sure how I could test that.
Well today, alternator didn't arrive, should arrive tommorrow.
So I got bored and I removed the postive wire > battery and ran the car with the alternator running to see what voltage was coming out of the postive alternator post.
I put my multimeter on the postive post and the ground on the alternator block and or engine block.
I only got 1v.
So I guess that perfectly stats the alternator is bad. It must have just died completely. Mabye the regulator failed.
Old 10-06-2007, 11:51 AM
This is beyond annoying. This makes me want to cry for petes sake.
New Bosch in, Was fine for about 15minutes then light came on.
I got my orignal somewhat still working alternator im just going to put that back in for now.
This is not right at all
Napa retested the battery, he said the battery was fine.
Old 10-06-2007, 08:12 PM
As I have nothing else to offer, I'll just say that many folks have gone through more than 2 rebuilds to get one to work. Good luck.
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 10-06-2007, 10:37 PM
What is the odd thing is this was a bosch brand. The one everyone recommends. And I did two of those.
What appears to be the issue, is mabye the cut on rpm is too high on this bosch's or somthing.
Or mabye wiring is different not sure..
But im sure a oem honda will do. But whatever. Thanks guys for the help.
Old 10-07-2007, 12:04 AM
I'd be irritated too.
As I have a bosch alt and it's been the best alt I've ever used; quality's probably taken a dive just as it does with everything.
1997 3.2L V6 Rodeo
Old 10-07-2007, 02:25 AM
trooperbc's Avatar
trooperbc trooperbc is offline
Klownicle... yikes,how frustrating. i think too it is possible that it's the 'new' alternator, but i doubt it.
it would appear there is *something* not right at all for sure; and it appears, from your experience so far, that the *something* must be within the charging system that is causing this problem. it almost rings a bell, but not quite...
thinking out loud...the newest bosch remanufactured unit worked fine for 15 minutes and then, zap you got the same problem.. did you do anything different in that period. did you try running w/o the audio turned on?
it's as if a short is creating an alternator-eating demon, or perhaps a diode-eating creature....you've been down all the paths, i know, but it still seems like it's some ground problem to me causing the electricity to search out a different path...have you tried disconnecting the audio, including the illumination connectors to see if that affects a change? have you tried tracing, ohm checking, the circuit that supplies the idiot light?
that's it so far....
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 10-07-2007, 10:18 AM
Not sure how to do any of that.
But again. Everything is PERFECT with my Core orignal. Only the 2 Bosch alts cause the lights to turn on and what not.
Both times the light came on at different times. And the light would flicker on and off as rpms changed. And at some point the light would stop flickering, and just be on solid.
Old 10-07-2007, 11:49 AM
If everything is PERFECT with your original core, then put it back in and leave it alone.
Your original thread was started because you were having voltage issues....IIRC
How do you know for sure that something wasn't shorting out your original alternator too??
1997 3.2L V6 Rodeo
