Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-04-2007, 11:49 PM
ddcoo ddcoo is offline
replaced alternator, have power but it won't start?
I just replaced the alternator on my 2000 Montana (3 day event). Everything is reconnected and I get power and full dash lights when key is turned to accessory. But if I turn the key to start the vehicle, there is no turn over and the headlights turn off (it was night so I think this is normal) while the key is in the start position. There is no turn over, no clicking, no signs of anything except the full lit up dash, radio, etc. HELP!!!
Old 10-06-2007, 01:20 AM
1Bradymichael 1Bradymichael is offline
Re: replaced alternator, have power but it won't start?
I am assuming you unhooked the battery when you did this job? It sounds like you have a positive or ground that is not making a good connection on your battery. This has happened to me before. You can have enough juice to light stuff up, but when extra voltage is called for, the connection is broken. I would double check your battery posts/pads. That, or your battery went south and gave up the ghost.
Old 10-06-2007, 09:49 PM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: replaced alternator, have power but it won't start?
Originally Posted by 1Bradymichael
... I would double check your battery posts/pads... battery went south ....
Seconded!
The positive post on the battery and the positive cable are notorious for corroding and causing poor connections. Disconnect the negative cable first and then remove the positive bolt and cable connector from the battery. Look inside the red rubber molded boot and you will likely find plenty of greenish corrosion. Baking soda and warm water will remove it. Clean the inside of the boot too. A stainless steel wire brush comes in handy for cleanup.
Clean the battery posts and use a bit of baking soda on them as well. Rinse everything off and dry with throw-away towels. You have a choice of using a film of grease on the cable connectors and bolts, or dielectric grease. Either one will do the job though.
Don't give up on the battery just yet..if you have 12.0 to 12.5 volts or more across the posts using a multimeter, the specific gravity of the battery is still high enough that it should hold a charge. But at 7 years it will soon be time for a new battery anyway.
Hope this helps.
