Go Back   Automotive Forums Car Chat > Jeep > Liberty
Old 10-04-2007, 05:55 PM
blevins6251 blevins6251 is offline
obd code p1494
does anyone know this could be caused by? changed the purge solenoid
Old 10-05-2007, 07:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: obd code p1494
This looks like some good info.
http://en.allexperts.com/q/Chrysler-...d-Cherokee.htm
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 10-06-2007, 06:45 PM
Re: obd code p1494
i have a 02 jeep liberty that has a obd code of p1494. i have replaced a hose that was cracked and fixed code p0442. after fixing this code came up. i was recommended to replace the purge control solenoid. but this did not get rid of the code. what else could it be?
Old 10-06-2007, 11:32 PM
AF - Advisor
Re: obd code p1494
The writer in the above shortcut refers to a leak detection pump and potential problems with it...setting off the trouble code. That's what I would look for first.
