Old 10-04-2007, 04:54 PM
burnchassis3 burnchassis3 is offline
4x4 no codes
Local trans shop here told me they could not get a code ,if the service 4x4 light is not on.
is this true?
I have a 99 lt the light flashes but it wont engauge.It will go into 4wd lo.
Can someone tell me where I should start looking to fix this?
What is most common to go out?
Thanks
CS
Old 10-04-2007, 05:05 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 4x4 no codes
233 or 236 transfer case?
A lot of times you can find a code stored in history even if the light is not on.
Also some codes do not turn on the light.
If a 236 get a good transmission/transfer case/engine capable scanner on it and check for codes past present or history and go threw the shifting test in the scanner.
If a 233 there is a way to ground pin 13 on diagnostic connector and get codes.
MT
MT
Old 10-04-2007, 05:16 PM
Re: 4x4 no codes
It has auto 4wd so i thinks it the 236.
Its going to cost me a 100.00 to see if its throwing a code.....Is there somewhere I can check to see If I can see a problem? linkage? relay clicks? anything?
I have a baby comin in a month..my 3rd and FINAL! so money is tight..any help is appreciated.Other than contraseptive helps lol.
Thanks
CS
Old 10-05-2007, 01:44 PM
MT-2500's Avatar
AF - Advisor
Re: 4x4 no codes
About all you can check without a scanner is fuses and wiring plug in.
It will run in 2W untill you can save up some dollars to fix it.
Even after you get codes to fix it you will have to repair something.
Good luck on the new one and finals.
Take of them first.
MT
MT
