Old 10-04-2007, 04:47 PM
2string 2string is offline
Amsoil 0W-30
Is 0W-30 oil OK for my 03 4.8? How many quarts does it actually hold with filter change?
Old 10-04-2007, 04:54 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: Amsoil 0W-30
Use the recommended oil weight that is in your user manual. I believe it is 5w-30. If you use anything thiner than 5w and thicker than 10w, then you could cause early termination to your enigne. If you truck is under warrenty, you could void it out.
How many miles on your truck? What year?
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 10-04-2007, 05:03 PM
Re: Amsoil 0W-30
2003 70k The Amsoil site recommends 0w-30 it's there first choice there second is 5w-30
Old 10-04-2007, 05:22 PM
Re: Amsoil 0W-30
So when your engine Fails, are they going to cover the cost to repair it?
I don't think so, even if they claim it you would have to prove it.
Don't take the chance.. use the manufacture's recommendation. 5w-30
Old 10-04-2007, 05:28 PM
Re: Amsoil 0W-30
OK,I think I would feel better using the recommended weight too. Thanks for your input.
Old 10-04-2007, 05:44 PM
rjeffery rjeffery is offline
Re: Amsoil 0W-30
Your 4.8 hold 6 quarts w/filter change.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 10-04-2007, 05:49 PM
Re: Amsoil 0W-30
Thanks, may I ask what you use for oil?
Old 10-04-2007, 06:31 PM
Re: Amsoil 0W-30
5w30 Conventional. Normally Penzoil or whatever is reasonably priced. Not the cheapest, but not the most expensive.
Old 10-04-2007, 06:46 PM
daman daman is offline
Re: Amsoil 0W-30
A 0w30 can be used in the winter(i use it too,Mobil-1 0w30) without issues,i woundn't use it in the summer tho...
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 10-05-2007, 06:08 AM
weo38 weo38 is offline
Re: Amsoil 0W-30
I also think that the 0W-30 oil may be more expensive. I used to run it but now run 5W-30.
2009 Z-71 ECSB
2007 Yamaha Grizzly 700 FI
Old 10-05-2007, 06:17 AM
Re: Amsoil 0W-30
Yes is is more expensive but amsoil says it's has more protection properties then the 5-30 and last longer.
Old 10-05-2007, 08:22 AM
Re: Amsoil 0W-30
Ever since it's first oil change I have always used Castrol GTX 5w30
I now have 160K miles on it and it has never hicupped.
I am thinking about switching to the High milage, but I have not decided yet.
Old 10-05-2007, 12:44 PM
knogoodidleft knogoodidleft is offline
Re: Amsoil 0W-30
Mobil 1 fully synthetic, 5-w30, every 3000 miles or so, 50+k no problems, I change mine so often because I run my truck hard, everyday. This last change I threw 1qt of lucas synthetic oil treatment in.
Old 10-05-2007, 01:52 PM
Re: Amsoil 0W-30
They say there's not much difference in standard oils,is there with synthetic brands?
Old 10-05-2007, 02:41 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Re: Amsoil 0W-30
I'm probably the roughest person on a silverado here(countless nitrous bottles put through it) and I've had zero problems out of my 6.0L. I've always and will continue to always use the Castrol Synthetic blend 10w 30. I figure that if its held up to what I've put it through, it has to be a pretty good oil.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
