Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 10-04-2007, 03:58 PM
BrianP BrianP is offline
Braking/ABS problem
2003 Yukon XL.
When I'm braking softly, just prior to the truck coming to a complete stop, it feels like the ABS is engaging. The brake pedal vibrates slightly. When I brake harder, the problem doesn't occur at all. Any thoughts as to what could be going on? The pads front and rear are in good shape so I know it's not that.
Old 10-04-2007, 06:28 PM
maxwedge maxwedge is offline
A990 racer
Re: Braking/ABS problem
That may or may not be the abs, excess rotor runout can have the same same symptoms.
Old 10-17-2007, 10:34 AM
Thanks for your reply. I had already had the rotors and pads checked and they are good.
Headed to the dealer service department later this week to see what the problem is.
Old 10-17-2007, 03:45 PM
2000CAYukon 2000CAYukon is offline
The ABS sensors may need to be cleaned. Common issue in the north east.
//2000CAYukon
Old 10-21-2007, 08:22 AM
handy1219 handy1219 is offline
Hi!
Very often either one of the censors goes bad or riety - which sauses the problem. sometimes very simple check by the mechanic can resolve the issue, assuming that everything is O.K. with the regular brakes.
Handy1219
Old 10-22-2007, 11:21 AM
To close the loop on this, I took it in and it was in fact a bad sensor. They replaced the right front "hub" which was as they said "dropping out". Not quite sure of their terms but that took care of the problem.
