94 3.8l plug wire loom
Greetings,
Started to replace plugs and wires on my 94 3.8l when I ran into a problem right off. Is there an easy way to remove the long plug wire loom or do I have to loosen the motor mount and rock the engine. Looks like it is blocked on both ends and doesn't want to slide anyway. I admit I am not the sharpest tack in the box, but I just don't see it. The book just says remove the loom. Thanks in advance, cowpie |
Re: 94 3.8l plug wire loom
I presume you are talking about the front wire loom under that cover..and that 94 is the same as my 95. First move the dog bone at the front of the engine out of the way, then lift the outer part of the wire cover straight up, it is held in place by tapered tabs. Good luck
Jeff |
