Old 10-04-2007, 01:10 PM
irvan36mm irvan36mm is offline
Passenger power seat-doesn't work
Hi everybody! This is my first time posting here.
I have a 2000 Intrigue GL. My front seats are powered,w/the heaters.
The passenger seat doesn't work when using the switch to move it up/down/fwd/backward,etc. Also,the heater for that seat doesn't work,either. The heater switch for the pass. seat will not light-up in HI or LOW. The Driver's seat is in perfect working order.
Recently,the pass. floorboard was soaking wet from the recent rains here in FL. I've since corrected that problem,using the suggestions found in this forum (Thank You,all!),and will have to check the blower fan next-but that's another story.
Is it possible that the seat wiring,hidden relays,fuses,etc, may have failed due to those parts getting wet? What areas should I check first?
BTW,the fuses for the seats in the passenger-side fuse box at the dash are intact & in good condition.
Other than that,it's a great car!
Thanks in advance!
-George
Old 10-04-2007, 10:26 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Passenger power seat-doesn't work
If it were me, id being going test-light crazy to see if power is getting to the motor/seat, and if not start tracing stuff back.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 10-05-2007, 12:16 AM
Thanks! I'll try that first & post what I find out.
Old 10-05-2007, 06:47 AM
Hoppy2 Hoppy2 is offline
Sounds like a bad ground or a bad fuse. Start there.
