Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 10-04-2007, 07:53 AM
jamesmetairie jamesmetairie is offline
05 starting problem===
2.5 (4)cylinders)= aprrox. miles - 137,000. automatic tranny. today flat out won,ty start and key stuck in ignition switch. battery about 1 year old and connections kept clean.. cat converter is brand new . turn the key and got only one click. even with the key in the "on"position no lights on the dash and no accesserys were working. this happened a couple of times in the past ,but at least it would try to start and eventually did start.
Old 10-07-2007, 10:36 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Re: 05 starting problem===
Check negitive battery cable connection down on trans...
Old 10-28-2007, 07:27 AM
whitecopter's Avatar
whitecopter whitecopter is offline
Had the same problem on mine. Do you have the stock battery in it? If so replace it. I ahd my stock battery just up and die when i had 50k on it. But havent had a problem since.
