Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-04-2007, 05:35 AM
bboy4life500 bboy4life500 is offline
94 intrepid has A BUNCH OF PROBLEMS need help!!!!
ok i just got this car and when you move the tilt stearing wheel alot of the things turn on and off. like the ac doesnt work all the time. ill turn it on and nothin, then ill hit the steering wheel and it turns on!?!?!? same with the temp or air it blows. and the same thign happens with the airbag light, the locks, and the windows. and theyres this wierd clicking noise that sounds like a um vacum valve that clicks after the ac is turned on and off . but it only douse it for a minute or so.
also thayres a miss as well, when it idles it gos form bout 750 rpm's to 500 and back every couple of seconds and bogs down,and the oil light comes on when it gos down couse its ready to stall. and the moter shakes, and the exquast puffs when it douse it too which im sure is the moter miss firing. how to i advance the ignition timing or check to see why its doing that????
And theyre is water that sprays out of the muffler too when it puffs? its clear and some black????
ive also noticed that the struts are bad and how much douse it usuallyt run to get them replaced????
please try to answer all these questions asap !!!!!!!!!!!! i know its alot but if i can find out how to fix them it would be great!!! THANK YOU
and if i didnt explain anything right just ask and ill try to make it better!!
Old 10-04-2007, 05:50 AM
Re: 94 intrepid has A BUNCH OF PROBLEMS need help!!!!
has anyone read this yet????
Old 10-06-2007, 10:00 PM
ok i guess noone knows or noone can think of a salution for me huh?? lol well if anyone has a clue please let me know thank you
Old 10-06-2007, 10:12 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF.
Sounds like you have some problems.......
on the freaky on/pff with the tilt, you probly have a short in the wire harness and when you use the tilt it shorts out more. You'll need to take a look to find these problems and will probley need the harness replaced.
If its missing out, try new plug & wires.
If that doesnt fix it check the coils.
A little water out the tail ppipe is normal due to condensation.
Struts run about $100-150 each depending on where you buy them, plus install. Might get a deal when replacing all 4 at once.
Hope that helps!
1999 Grand Am SS 3.4 OHV
Old 10-06-2007, 10:23 PM
yes that helps alot thank you!!! i will try those things and see if it works!
Old 10-17-2007, 01:22 AM
alright well ive torn apart the stearing colum and founf that the black plastic ignition switch box is somehow shorting couse when i push on it , it turns eveything on and off. and on the other end of it is the key which i can giggle and it also turns everything on and off. Also the hazerd button dousent work and sometimes makes the blinkers not work eather so i have to push it a bunch of times until it sticks a little to get the damn blinkers to work. so what i am doing tomorow is going to the junk yard and pulling out a whole damn stearing colum. weal and all and replacing it! and prayin that the one i get douse'nt have the sam problem!!!! hope this works !! lol
