Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-03-2007, 10:34 PM
Russell01 Russell01 is offline
Question non-turbo2.0 to turbo 2.0 swap..NEED HELP
what all has to be done when doing this swap. the turbo motor is coming from a lazer and going into an eclipse. will the computers have to be swapped? any help is appreciated
Old 10-03-2007, 10:35 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: non-turbo2.0 to turbo 2.0 swap..NEED HELP
What are you trying to do? Swap a turbo motor into a NT car? What year eclipse are you trying to do this in?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-03-2007, 10:44 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Read the FAQ please.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-04-2007, 02:17 PM
this is a 93 eclipse. the lazer is the same body style. im wanting to put the 2.0 turbo in a non turbo car. i know nothing about mitsubishis and any help would be appreciated.
i read the FAQ...ok. no help there...
Old 10-04-2007, 02:32 PM
Holset powered 420a
The 93s had the 4g63nt so it should pretty much be a direct swap. You might have to change the ECU but everything should pretty much be the same.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-04-2007, 02:55 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yes you will need a turbo ECU and wiring harness.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-04-2007, 09:16 PM
thats all? is it hard to change the wiring harness? does it run through the firewall? ecu inside cab or inside engine compartment? thanks again...whats the hp difference in these motors?
Old 10-04-2007, 09:33 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
It goes from 130hp to 195hp. The ECU is behind your radio.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 10-05-2007, 04:39 AM
Thor06's Avatar
Jizzed In My Pants
Yes, it will be a harder swap. Not because its difficult, but because you have made it obvious that you dont know what you are doing. I'm really not trying to be a dick here, but you should definately do some reading before you go through with it.
What years are the cars involved?
Old 10-05-2007, 06:48 PM
its my friend who is doing it im just making sure theres nothing that would not allow this swap. thanks for all the help
