Old 10-03-2007, 09:07 PM
mustangmike_1981 mustangmike_1981 is offline
98 cavalier overheating. please help
My cavalier is running very very warm. i flushed the radiator and put in new antifreeze. at idle it does not overheat, but runs near the Hot line. once i start driving, around town it stays about the same, when i get on the highway after about a mile it starts to rise to hot. after i stop the car to check the coolant again, i can hear a popping in the overflow tank. i figured there was just air in the system, so i ran it and kept putting more coolant in. is it possible that their is a blown head gasket and air is getting in the system?? any help would be great.
thanks
mike
Old 10-03-2007, 09:08 PM
Re: 98 cavalier overheating. please help
. oh i forgot to mention, i also removed the thermostat and placed in a pan of hot water to make sure it was opening and it did. so i reinstalled that. thanks
Old 10-06-2007, 01:32 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
try flushing your heater core
Old 10-06-2007, 02:42 PM
inafogg inafogg is offline
with engine warmed up radiator cap off check for curculation.you should be able to tell by reving the throttle.if not possible water pump.also make sure nothing is blocking radiator(paper/plastic bag)if it only overheats at highway speeds it sounds like improper coolant/air flow.check to make sure you dont have callapsed hose some where.
Old 10-06-2007, 03:36 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
did you make sure that "hot water" was the exact same temperature the thermostat is rated at when it opened? what i mean is if its a 180 degree thermostat, do you KNOW it opened right at 180 degrees? or could it have opened at 200, far after it was supposed to.....?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
