Old 10-03-2007, 08:38 PM
paleohunter paleohunter is offline
Angry s10 brake problems
i have 2001 s10 4x4 brakes seem to be dragging very bad the futher you drive it. has anyone had this problem and if so what was fix. has new pads installed, has been bleed by the book and still no luck . please helprunaround
Old 10-03-2007, 08:56 PM
old_master's Avatar
Advisor/Moderator
Re: s10 brake problems
Welcome to the forum!
What pads were replaced? Which brake(s) are dragging? Were the rotors machined or replaced? Was the hardware replaced? Were the calipers replaced?
It could be that automatic transmission fluid was inadvertently added to the brake reservoir, contaminating the system. Could be a binding caliper piston or hardware, even a restricted flex line, or a stuck park brake component. We need a little more information.
Old 10-04-2007, 03:09 AM
pipelinerr pipelinerr is offline
Send a message via AIM to pipelinerr
if its a front brake thats dragging it could be an imploded rubber hose. to test find which wheel is dragging and open the bleed just a little for a 1/2 second and close it. if the wheel frees its the hose
Old 10-12-2007, 07:41 PM
replaced all pad as it has 4 wheel disc brakes ,rotors where replaced . brakes where bleed but did not bleed right ? started as book says but only get fluid out of rear on first round of bleeding running or not. second round no fluid. front brakes drag bad will lock front wheels on pavement. can bleed one caliper and fix problem does not matter which one. all hardware was cleaned and greased.help
Old 10-12-2007, 08:26 PM
old_master's Avatar
Advisor/Moderator
When replacing pads and rotors, it is not necessary to bleed the hydraulic system. The only time the system requires bleeding is if a leak occurs. If the vehicle is equipped with ABS and the master cylinder goes dry, an ABS capable scan tool is mandatory to bleed the system. That may be why you're having trouble bleeding the system.
Old 10-13-2007, 07:01 PM
bleed system to try to fix problem with system holding pressure when brakes not applied.thought might be air in system heating up and expanding.master cylinder did not even get low so thats not a problem. did not bleed brakes because i put new pads on why would anyone do that unless they had to loosen a line.anymore ideals?
Old 10-13-2007, 09:02 PM
old_master's Avatar
Advisor/Moderator
Which system is holding pressure, front, rear or both? Or is it just one wheel? If you open a bleeder valve, does the wheel turn freely?
Old 10-20-2007, 07:48 AM
seems to be front holding can crack bleeder on either wheel and they release all wheels
Old 11-11-2007, 08:43 AM
toby1587 toby1587 is offline
bad caliper
