Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 10-03-2007, 07:17 PM
samturner samturner is offline
K&N Air Filter
I have a 91 Cougar SL 3.8 runs great now has about 50,000 miles on it. I am getting ready to change the air filter. Would replacing with the K&N air filter be a good or bad thing. I am not looking for better performance other then maybe a little better gas mileage am getting around 24 mpg combination city and highway.... On the city, its really small towns most of them do have two or three stop signs...
Appreciate any imput would hate to give it more air flow then the factory calls for if harmful.
Old 10-04-2007, 11:37 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: K&N Air Filter
A k&n air filter can do nothing but help your fuel economy.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-09-2007, 07:02 PM
vortecman's Avatar
vortecman vortecman is offline
Re: K&N Air Filter
and foul your mas air flow sensor if you add too much oil......
Old 10-09-2007, 08:17 PM
Re: K&N Air Filter
Which is a 30 second fix.
Installed correctly (which isnt hard to do), youll be fine.
"The CEG Nazi"
www.contour.org
Old 10-15-2007, 07:45 AM
Re: K&N Air Filter
I got the K&N Air Filter and installed it. I think it was well worth the money. Better mileage and car seems to run better. Easy install I followed K&Ns directions.
Last two times in for service I had the air filter checked and was told it was OK. I asked them to replace it anyway last time and they told me they didn't stock that filter.
When I installed the K&N I found the air box was not hooked at the bottom and the bottom of the old air filter was coming apart.... So much for quick oil changes..... I started to think I had a problem with them when they asked me if I wanted them to check the fluid levels.
I now have them on order for my other two running vehicles.
