Old 10-03-2007, 06:43 PM
daman daman is offline
Turning off ABS light?
Replacing the wheel sensor this weekend just wondering will it
go off it's self or can i clear it or does it have to be cleared with a scan tool??
this is on my '99 OBS Z71
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 10-03-2007, 06:58 PM
maxwedge maxwedge is offline
A990 racer
Re: Turning off ABS light?
The ABS does a self test, if all is ok the lite goes off.
Old 10-03-2007, 07:04 PM
That was my first thought, thanks Max..
Old 10-06-2007, 03:26 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Yes the light should go off by itself if everything is all good. But you can also unplug the battery to reset your codes.
Old 10-06-2007, 07:02 PM
Not on OBDII ?
Old 10-06-2007, 08:36 PM
Ok if you disconnect the battery then reconnect it, the code will still be stored in the computer as a previous issue. BUT, if you disconnect then reconnect the battery it also makes the computer to rescan everything and will only kick on a light if the problem (or a new problem) is still there.
Old 10-08-2007, 11:11 PM
Update...
light when off it's self when i started her up,didn't need to do
anything.
Old 10-09-2007, 02:53 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I've seen the light stay on after disconnecting the battery even after the problem was fixed. Couldn't tell you for sure what kind of vehicle though. Think it was a Chevy...
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-09-2007, 02:56 PM
emt1134 emt1134 is offline
My suggestion is to go to a GM dealer that you may have a good relationship with and ask if they can just clear your codes with the TECH 2. It takes a total of 2 minutes MAX. If they aren't complete a**holes, they will just do it out of kindness.
Old 10-09-2007, 03:03 PM
A990 racer
It is unecessary to clear codes if the problem is corrected, as I said in my earlier post.
Old 10-09-2007, 03:08 PM
The light will not come on, but if you want to do things right, you should always clear the codes even if they are just in history.
Old 10-09-2007, 03:10 PM
J-Ri's Avatar
It's hard to find a mechanic who'll do anything for free. It's not an issue of being an a**hole, but rather having spent $3,000 or more on a piece of equipment and having someone ask to, essentially, borrow it. If you did the work yourself (why else have them only clear the code(s)), you clearly aren't a loyal customer and they have no reason to want you to come back. Plus, a lot of customers will ignore the signs that say "Please use front door" with a big arrow pointing to the front door, and come in and ask me if they can borrow a screwdriver, hammer or whatever else. Mechanics eventually get to where they just want that annoyance out of the shop so they can get back to work.
Old 10-09-2007, 03:19 PM
I said, find a dealer that you "may have a good relationship with". Often, people own multiple cars that were bought at the same dealership, and have had essentially most of their service work done there. Just because someone does a job themselves, doesn't make them unloyal. I know the way the business operates, I am a technician for General Motors. It is not uncommon for a service advisor to grab a TECH 2, go out to the customer's vehicle, and then say, "ok you're all set."
Old 10-09-2007, 05:18 PM
like you said it takes a matter of 2 minutes max.
