Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 10-03-2007, 06:09 PM
RallyEclipse98 RallyEclipse98 is offline
Send a message via MSN to RallyEclipse98
Transmission fluid change questions
'96 Oldsmobile Ninety-Eight 3800 V6, transmission has about 150,000 miles on it.
I'm wondering if it would be better to do a fluid change or just top off how much it's low by (if it is). Also, where's the plug, reservoir, filler, filter at? I'm trying to put off buying a Chiltons/Haynes manual as long as I can. Why I'm needing to check it is because it hasn't been changed for a long while and I got a CE Light and the transmission won't shift as easily and won't even want to go into overdrive. Anyone know the answers? Thanks! Sorry of the noobiness.
"Staging in the Dodge lane is a Talon, or Eclipse, or Plymouth, or Mitsubishi... Ok, I don't know what the hell it is, but it'll be turbocharged and it's going to school this Mustang." - Announcer at a track
DSM power.
Old 10-04-2007, 10:47 PM
hoofit hoofit is offline
Re: Transmission fluid change questions
Check the trans fluid after it warms up and if needs some, put some trans repair fluid in. auto zone has it i think the best is marvel mystery oil or perhaps an auto zone brand. to change the fluid you know u have to drop the pan and get a gasket and filter kit. ( very cheep ). take down the pan, without making a mess, the filter is right there staring at you. replace the filter, clean the pan gasket and replace. use some gasket or rtv to help seal the pan. tork bolts from midle bolts outward and go over the bolts 3 times DO NOT OVERTIGHTEN the bolts. fill and run and check the fluid that you spilled all over the place and hopefully some got in a good clean pan. If here is shavings that SPARKLE in the oil GOD BLESS. good luck
Old 10-06-2007, 12:50 AM
Is there a dipstick for the trans fluid? I suppose there is.... I'm going to go with the OEM brand fluid/filter though because it's proved itself this far. No sparkles or else I'm going to !!!!!!!!
DSM power.
Old 10-26-2007, 06:09 PM
WTF? I just priced a filter from Napa Auto Parts and it was $25 just for a filter!
DSM power.
Old 10-26-2007, 07:42 PM
maxwedge maxwedge is offline
A990 racer
Usually includes the seal and gasket, I believe.
Old 10-28-2007, 01:34 PM
The one I priced only came with filter. Anyone know of a site I could go to get the filter etc. or could I just use the filter that's on it now??
DSM power.
Old 10-28-2007, 02:52 PM
A990 racer
AZ was 21.00, for entire kit, I just called, you cannot leave the old filter in there!!
Old 10-30-2007, 05:29 PM
Sorry, I meant to say old gasket, but I'll just find a complete kit.
DSM power.
