Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 10-03-2007, 04:54 PM
ChevroletTough's Avatar
ChevroletTough ChevroletTough is offline
Send a message via AIM to ChevroletTough
1995 Z34 (3.4L DOHC) Coolant Leak
1995 Monte Carlo Z34 DOHC.
So my belt has been squeeling for the past few times ive started up my car it basically goes away after awhile. I just noticed today that there are a few drips of antifreeze underneat my car. I checked the uppper, lower and by-pass hoses, they are all fine. The thermostat housing is also fine.The leak is right under the accesories on the passenger side, towards the front left corner (if looking down at the engine with the hood open) My guess is the front corner of the head is blown out a bit.
Any input?
This only proves that the 3.4L DOHC engine is crap... And if it is the head gasket, then im sure the rear head gasket is right behind this one..... so i might as well replace both of them, if that really is the problem.
1989 Silverado 350cu TBI
Aaron
Old 10-03-2007, 05:20 PM
wafrederick wafrederick is offline
Banned
Re: 1995 Z34 (3.4L DOHC) Coolant Leak
Put a pressure pump on to find the leak and that is an easy way to find the leak.You do not want to get inside this engine,you need the special tools made by Kent Moore made for GM which are not cheap.There is a special tool to hold the cams in time.
Old 10-05-2007, 02:48 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Check the water pump. Very common issue on GM 60 degree V-6's , and it's located in spot you say the coolant leak is. Take the serp belt off, and see if there is lateral free-play in the pulley. Also look for signs of coolant leaking out the weep holes in the water pump casting.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-05-2007, 04:00 PM
After another look, I think you guys are right, its the water pump. Good thing the pump is right upfront, i can't imagine replacing the alternator... bottm back of the engine. I think i'll take off the cooling resivor, then drain the radiator, replace the thermostat, replace the bypass hose (needs to be replace) and possibly the lower radiator hose, and then pull the waterpump off, replace it (of course making sure the surfaces are cleaned) then flush the entire coolant system.
I will make for damn sure its the water pump before i invest this time and money though!!
thanks for the info
Aaron
Old 10-06-2007, 11:01 PM
ok put it on a lift and looked... its the head. DAMNIT!! so im going to put some stop leak pills in the radiator and pray to god that seals the B up!
Aaron
Old 10-07-2007, 03:49 PM
great news!! Those pills i put in my radiator sealed wherever the leak was... up! Ive been home for 4 hrs and ive been going out periodically checking under my car... and NO LEAK!!!! The car Gods were on my side today. And even my oil leak stopped, that oring must have finally swelled
"Its gonna be a good day tater"
Aaron
