Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 10-03-2007, 08:30 AM
92v6beretta 92v6beretta is offline
Send a message via Yahoo to 92v6beretta
Unhappy Need ideas for gas door
I have a 92 3.1 beretta. The gas door rusted off along with the hinge & mounting plate . Any ideas or mods ? Please contact me at [email protected] . Thank you
Old 10-03-2007, 03:40 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Need ideas for gas door
Get a piece of cardboard and some duct tape. Duct tape the cardboard over the hole. Reapeat every time you fill up.
Or you could just leave it be.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-03-2007, 06:28 PM
jsgold jsgold is offline
the whole thing is held in with 2 bolts. Should be easy to remove what's left of the hinge bracket. Very common problem on Berettas and Corsicas. Just remove the bracket and then head to the junkyard, find a decent one, and then touch it up with rust paint and matching paint to yours. Then switch covers or paint it. Stay away from dealer. These hinges used to cost 25 bucks now over 90 at GM. maybe even higher now. Have had to replace on every one we have owned. Got lucky last time and found one that had actually been replaced before, in great shape. The bolts and remaining part of hinge should be found in the rear wheel well. Takes number 10 socket.
I used to be indecisive, now I am not so sure.
Old 10-04-2007, 05:37 PM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
hope this helps... asylum motorsports @ www.berettastuff.com
Old 10-05-2007, 07:02 AM
I may not have explained it enough. The door and hinge are fine. Its the part where they mount to; that is mounted (welded) to the car. Do they make an after-market gas door ?
Old 10-06-2007, 06:45 PM
anomaly_va_1976 anomaly_va_1976 is offline
I would just put a locking gas cap on it if you are concerned with someone spiking your fuel..... only other thing I can think of is remove the fuel tank, and sandblast the general area to remove the rust, then weld in new metal to make a new mounting plate.
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
Old 10-21-2007, 10:37 PM
loosenut74's Avatar
Autozone has them...
unauthorized link removed by Moderator
Last edited by '97ventureowner; 12-15-2009 at 09:21 AM. Reason: [I]unauthorized link removed by Moderator[/I]
