3 degrees more?
I am about to buy a tuned PCM for my '97 GTP and I see that there is an option to add +3 degrees of timing or adjustable timing tables. I am thinking about using the +3 degrees of timing option. This PCM is from the W-body store. Here's the link>> http://www.wbodystore.com/grandprix/...pcm-p-198.html
Also, I see a delete option for this >> Random/ Multiple Misfire DTC Would these be wise choices when ordering my PCM? I run 93 octane and an additive. Who does the best tuned PCM's for our cars? Thanks alot! |
Re: 3 degrees more?
If your GTP is a daily driver....no! My question is what mods do you currently have or plan on getting to support custom programming of this nature? I would not get the delete option for Random/ Multiple Misfire DTC unless necessary. This option is for when running hot cams that can set off this DTC which is P0300.
Re: 3 degrees more?
Yes, it is a daily driver. My mods will be as follows: 3.3" mps, JMB 4" FWI, Powerlog, 3" offroad downpipe, 180 drilled t-stat, 1.9 ratio roller rockers, throttle body spacer, etc... and eventually a 2500 stall.
Re: 3 degrees more?
Ok...now we're getting somewhere.
With your mods the 3 degree timing will be fine but you're stuck with the 93 octane or better fuel. Pass on the random misfire delete. Not needed unless you plan on an aftermarket cam. I use the SLP 1.8 roller rockers in my GTP and know this is not a problem with aftermarket rockers. Here are some additional guidelines from Intense Racing concerning timing and what custom programming to go for.Quote:
Re: 3 degrees more?
Thank you very much for your help! |
