Old 10-03-2007, 04:10 AM
chevyman4life chevyman4life is offline
Exclamation 2000 cavalier
the other day the radiator resivoir exploded on me so i replaced with new and now i got oil comeing up out of one of the spark plugs and kinda of concerned what might of happend im kinda stumped on this one cause my water level is down to??????????????????????????????????????
Old 10-03-2007, 07:24 AM
shakewell shakewell is offline
Re: 2000 cavalier
If your resevoir exploded your water level should be low, no? Is it running ok? Does it keep overheating?
1. Replace your radiator (resevoir) cap.
2. See if anything improves.
3. Quit freaking doing this: ?????????????????????????????
It's like you saved all of your punctuation until the end of the post.
Just trying to help .. .. ..
Old 10-04-2007, 01:08 AM
Re: 2000 cavalier
i replaced the resivoir and filled with water to check the system out and now i what looks like oil comeing from one of the spark plugs?
Old 10-04-2007, 05:45 PM
Re: 2000 cavalier
Well your valve cover gasket could be bad but that wouldn't cause the resevoir problem. I can't help more unless you answer the questions in my first post.
Old 10-05-2007, 01:10 AM
Re: 2000 cavalier
the resivoir exploded because my engine fan dont kick in to keep the engin cool while it is idleing so it over heats when running and sitting still so i tried to shut it off that night that it happen but i fell asleep in the parking lot before i got it shut off because i had just worked a 43hrs straight before and was sitting and waiting on a friend and fell asleep thats what happen there.
Old 10-05-2007, 01:19 AM
Re: 2000 cavalier
You might have problems that I can't hep you with then. This might help some
Old 10-11-2007, 01:03 PM
Re: 2000 cavalier
i now have water in my oil i know what that might be but i have fuel smell in my resivoir that i have no clue on?
Old 10-11-2007, 03:23 PM
1991tercel 1991tercel is offline
Re: 2000 cavalier
So because you didn't want to spend $20 on a fan motor you let your car overheat and blow your headgasket. Now your $20 fan motor is going to cost
$20 for the fan motor (still)
$10-$15 for the resivor for the collant
and from $100-$1,000 for the head gasket to be replaced. The gasket is fairly cheap but if your motor got hot enough to blow put shit then you head it most likey toast.
A head is probably $100-$300 and then the parts inside could be transfer from your old head.
Old 10-11-2007, 05:04 PM
inafogg inafogg is offline
Re: 2000 cavalier
fuel smell is probily misfire from not burning gas. as the plug fouled
from water in oil. thus the gas ends up in the oil because it wasnt burned
Old 10-23-2007, 04:27 PM
TooMuchRock TooMuchRock is offline
Re: 2000 cavalier
Fan goes bad in the cavalier around 100k.
Even after replacing this, had to replace entire head gasket and remachine the head.
Cost around $500 for the labor and parts, and that was because a friend of mine did it.
Old 10-24-2007, 11:20 AM
Re: 2000 cavalier
head gaskets and 2200's don't mix well
