Old 10-03-2007, 03:32 AM
beaser beaser is offline
caravan ac 1998
the clutch on the ac compressor will noy engage. i have checked the charge on the low side ( 25 psl at 65 degrees ), the fuse is good and the relay is also good. my problem is no power at the plug on the compressor. any suggestions.????
ps i can jumpper the clutch and it will engage.
Old 10-03-2007, 07:41 AM
Bear Bear is offline
Re: caravan ac 1998
25 psi at 65 F is to me a bit low, I would recharge her to between 32 psi and 34 psi and see if that helps.
