Old 10-02-2007, 05:56 PM
jcc3inc jcc3inc is offline
False EGR code ???
Good afternoon,
My 97 with 90000 miles on it has had some EGR problems lately. After the first incident, I removed the EGR and checked and cleaned it, replacing it after clearing the code. Maybe 1500 miles later the same code reappeared.
This time I bought a new EGR and cleared the code. After maybe another 1000 miles the light came on again. This time I ignored it and in due course the light went off. A couple of weeks ago the same code, P 0401 (insufficient
EGR flow) came back.
This aft I reset again. Friend John says he read somewhere that this code can be set by other than EGR problems - something about throttle position sensor and ???
Has anyone had this EGR code reappear several times as I have had? And did you determine the real cause?
Thanks in advance.
Regards,
Jack C.
Old 10-04-2007, 09:36 PM
Blue Bowtie's Avatar
Registered Offender
Re: False EGR code ???
Exactly what code number (DTC) was generated? There are several relating to the EGR.
Old 10-04-2007, 11:01 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The PCM module uses MAP (manifold absolute pressure) to test EGR flow. A common overlooked problem for DTC P0401 on a Series II 3800 engine is related to the PCV valve. So check to make sure you have the o-ring seal on the PCV valve. The PCV is located under the MAP sensor located on the right hand (passenger) side of the UIM plenum.
Timeslip 08/12/06
AF Community Guidelines
