Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-02-2007, 05:49 PM
shaneland shaneland is offline
Ignition Switch
1979 Crown victoria...
Ign switch is broken. I bought another one but cant get the old one out...
HELP
Old 10-07-2007, 09:05 AM
Re: Ignition Switch
Noone knows how to get an old ign. switch out?
Old 10-07-2007, 01:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Ignition Switch
ignition switch or key cylinder?
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-07-2007, 03:24 PM
Re: Ignition Switch
well the key cylinder came out.
In the process of trying to replace the key cylinder my neighbor drilled it out. Now I dont know what to do...
Old 10-07-2007, 04:34 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Ignition Switch
If the entire cylinder has come out, use a screwdriver and stick it in the slot. Twist it until the dash lights come on. Hold new cylinder and turn the key to on position. Line up cylinder with grooves and install. When it bottoms out, turn the key off and remove. This will allow the locking poin to come out and lock the cylinder in place.
Old 10-07-2007, 04:46 PM
inafogg inafogg is offline
Re: Ignition Switch
if you are replacing key/tumblers.your neighbor drilled what??where you put
the key in??if so,pull steering wheel(no air bag right?)unbolt horn & turn signal sw.& move it out of way.remove lock pin/screw & pull out key/tumbler.
you have to remove turn sig. sw. & tilt levers
disconnect battery before you start Good Luck!!
Old 10-07-2007, 06:37 PM
way2old's Avatar
TOKEN HILLBILLY
Re: Ignition Switch
Go to this site. It has instructions on how to install.
