Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Avalanche
Old 10-02-2007, 04:49 PM
ksavalanche ksavalanche is offline
Driver Side A/C blowing hot
I have a problem with the dual temperature A/C on my 2004 Avalanche. The driver side air is blowing hot and the passenger side is blowing cold. I checked the compressor an it's working properly. What could be the problem here?
Old 10-03-2007, 09:39 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Driver Side A/C blowing hot
You need to check for low R-134a.
Post back high and low pressure readings at idle and at 2K RPM.
Also a good body capable scanner will test and show codes if a problem on the automatic AC/Heater system.
MT
MT
Old 10-04-2007, 05:01 PM
daman daman is offline
Most times that condition is caused by low freon,whats happing is the
evaporator is only half cold because the systems low on freon..
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
