Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-02-2007, 03:40 PM
Sergeia Sergeia is offline
Send a message via Yahoo to Sergeia
Lightbulb AT Transmission Exchange 98 Contour
I have 98 Contour with 2.0 auto transmission (F83P-DB) .Does anybody have info . how to change it step by step ? Do I need to put down subframe to take it out ?Can I install XS7P-CA or XS7P-CB instead or I need some kind addapter to do so ?
Old 10-06-2007, 01:13 AM
Davescort97 Davescort97 is offline
Escort guy
Re: AT Transmission Exchange 98 Contour
I don't know about the different transmissions. Your best bet is to go to the parts house and buy a Haynes manual for your Contour. It will have the step by step process to change over your transmission. Will also have some helplful pictures to guide you through the process. There are about 27 steps to do this. Get the manual. It's only about 15 bucks.
Old 10-06-2007, 11:05 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Id PM todras on contour.org. If his prices are still the same, he sells CD contour manuals for $8 shipped.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-06-2007, 09:10 PM
Thanks for replays .Just bought wrecked 98 Contour with only 35 k on it cost me $300 (whole car).Trany is match.I will do swap in next couple days
Old 10-07-2007, 12:31 PM
wafrederick wafrederick is offline
Banned
Make sure the ground wires are in the right spot and it is a pain in the butt to change.I seen my father change one in the newer body style Mercury Couger which is the same body style as the Contour.If you put the ground wires in the wrong spot,you will burn up the transmission up.
Old 10-16-2007, 06:49 PM
Finaly done with it .Yes it is a hard one .difficult part is puting motor and trany together.Took me almost 2 days .Because I have no air tools and was working outside on driveway.With right tools should be couple hrs job .If anyone need 'how to do it' let me know
Old 10-16-2007, 06:58 PM
Old 10-22-2007, 12:14 AM
mitchcity mitchcity is offline
could you tell me how it's done I have a 1998 ford Contour GL AT Transmission
