Ok so i went to take the tire on the front passanger side off the exploder. And 4 outta 5 lugs just spin so i know there not seated in the hub but i think the hub is wore out so and idea on getting the lugs off with out using a chisel would be great. i have tried to use a chisel but thats taking to long
Re: 94 explorer wheel problems
Did you try retightening them? Maybe if they retighten you can break them off. Just a thought.
Or use an open end wrench on the nut and using a srew-out by drilling into the stud?!?!!? Not really sure. |
This may be a dumb suggestion, but are you sure you're using the right size socket? If your '94 uses the chrome covered lug nuts, maybe the chrome covers are missing from those 4 lug nuts so they are really an 18 mm rather than a 19 mm. You were using a 19mm socket, right?
-Rod |
yes in using the right size i cut the covers off i can see the spin together i have something im going to try in the morning ill see if it works let yall know
