| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
i swapped the oem EPROM chip with the DSMlink chip, put the computer into my GST, swapped the spark plug wires, and was ready to go... i put the key into the on position and the car starts clicking/viborating a ton! turning the key more it just cranks, and cranks, and CRANKS i let off trying to start it, and the car started to click/viborate again, and the injectors where not pulsing (the reason for not starting)... however, i had pressure in the fuel rail, so i pulled the computer and checked for bad caps, shorts, etc. found a few shorts, and repaired them... put the link chip back in the EPROM, and put it all back in the car, turned the key to on, the relays where normal at first, turned the key, cranked and cranked again, but would start returned to the on position, and the fucking clicks/viborations started again!... i checked for spark, and that was good... after a few attempts, i swapped back to the OEM '99 computer, boom! fired right up! shut it off, and put my eprom ecu back in... no better results... any help guys?
![]() it wont connect to my labtop ever time i try i get "command timed out" so i cant verify.. Here is exactly the Email i got from DSMlink uppon purchase! > Product: EPROM Only > Shipping: Ground > Payment: PayPal > > Injector: FIC 950 > Idle: 750 > Launch: NONE > Rev: 7500 > > CAS: yes > Hack MAF: no |
Re: wont start!
Maybe the ecu is bad
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: wont start!
Re: wont start!
It will depend on how bad it is I guess. You might want want to call them and see what they say.
Re: wont start!
i just emailed them... and well see if they can give me a lead on where to start looking for problems... i wish i could find another Eprom that i know works... i know its a long shot, but does anyone have one they would like to pass on to a friend in need?
Re: wont start!
I think whatever it is, is a common problem to happen to DSM ecu's as my ECU took a dump on me with the exact same symptoms.
Where did you buy the ECU from? Can you get your money back for it?
1991 GSX 2.3 Stroker |
Re: wont start!
i bought about a year ago on dsmtrader... dont think i can get my money back, but i do think i can fix it! The clicking sound i hear is from the ECU resetting a number of relays every time it reboots (several times a second). It's rebooting because the socket job is bad...
http://wiki.dsmlink.com/default.aspx...t2GSocket.html check it out! |
Re: wont start!
Good luck with that man.
Re: wont start!
anyone know what chip on the ECU is IC1 and what is IC2? i know what the Eprom is (thank god!) but this IC talk is new to me...
Re: wont start!
Ic1 and Ic2 are Temperature Sensors if I am thinking right.They are usually the largest chips on the board.Some one tell me if I am wrong lol.
Re: wont start!
ok checked the computer with a meter, and found the problem... pin 28 on the eprom wasn't getting the required 5 volts to function, i fixed the connection and boon! car fired right up, plugged the labtop in, and wham logged no problem! AWESOME!
Re: wont start!
Nice, theres probably not to many people who would take the time to track a problem down like that.
Re: wont start!
