Old 10-02-2007, 11:10 AM
jshort74 jshort74 is offline
93' c1500 4.3L squeaks at low rpm
My 93' c1500 4.3L manual has a funny squeak. I hear it only at low speed when I let off of the clutch pedal and give the engine gas to accelerate. It increases with the speed of the truck not the RPM of the engine. It goes away if I push in the clutch pedal. If I release the pedal it comes back again. I recently replaced the clutch on this truck and I didn't start hearing the squeeking untill 2-3 months after the replacement. Any ideas?
Old 10-02-2007, 02:54 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 93' c1500 4.3L squeaks at low rpm
My first thought would be the U-joints
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 10-02-2007, 03:44 PM
UPDATE: I put the rear end up on jack stands, started the truck and put it into gear. No squeak. I gave it some gas, no squeak. Also, there seems to be no squeak in reverse. Thanks for the help.
Old 10-02-2007, 08:06 PM
777stickman 777stickman is offline
I agree. U-Joints under a load would be the 1st suspect. Even though they may feel tight.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
