Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-02-2007, 10:48 AM
diepolder5 diepolder5 is offline
96 Rodeo Charging Problem
ok first let me say i have read through most of the osts ot here on this and i have not seen anyone with the same problem i am having. I have no 12v signal to the pcm. If i remove the red connector from the pcm i get my signal back. I have gone through all the grounds on and around the engine thinking i had a bad ground and it was being pulled through my signal. I have replaced the pcm and still have the same problem. The alt is brand new and not a rebuilt. The only thing not working on the truck is the spedo. truck runs good with no codes showing at all except the speed sensor. I am thinking i might have a problem with one of the sensor's but not sure at this time
Thanks for taking the time to read my post.
Old 10-02-2007, 11:04 AM
Klownicle Klownicle is offline
Re: 96 Rodeo Charging Problem
Not that I know anything about cars.
But, you said its a red wire? Perhaps a red wire with white stripes?
Anywho, someone once told me (I think your year) had a voltage regulator that was built off your alternator. And they said it was killing there alts and voltage. They removed a red and white stripped wire and there problem got solved.
Not sure if that helps. But ehh.
Old 10-02-2007, 12:32 PM
Reg is in the alt on this thiing it's a late 96 with 97 parts Thanks
Old 10-03-2007, 12:31 AM
Ramblin Fever Ramblin Fever is offline
Where'd you locate a brand-new alt?? What brand/part number is it; all I can ever find is rebuilt OEM's or rebuilt by Bosch
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
