Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-02-2007, 08:15 AM
Walleye catcher Walleye catcher is offline
Will start but will not run
1991 Plymouth Laser 2L (no turbo) will start but will not run, the fule pump only has power while the ing key is turned.And the test plug on the fire wall behind the battery will not power the fuel pump ? The car will only run if I hot wire the Fuel pump, any help would be grate.
Old 10-02-2007, 08:49 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Will start but will not run
Hmm did you check all the fuses? Did you try swapping out the fuel pump relay? When you first turn the key to the on position do you hear the fuel pump turn on for a couple seconds? Obviously your fuel pump is working. If worse comes to worse you can always rewire the fuel pump with bigger gauge wire. It's mostly done for performance reasons, but it would work in your case as well and you will get constant battery voltage to the fuel pump rather than 9 or 10 volts with that factory gauge wire.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-02-2007, 05:13 PM
Thanks TalonEclipse GSX for the post,But all the fuses look good allthough I did not find one marked fuel pump. The parts store can not find a fuel pump relay in there books for this car so there may not be one ? And no the Fuel pump does not come on with the key in the run position only the crank position. I have been told it could be a bad Ing switch,?
Old 10-02-2007, 06:09 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
There is a relay for the fuel pump behind the radio on the floor near the ECU.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 10-02-2007, 07:35 PM
Yep. It is also called an MFI relay, which is probably why the parts store couldn't find it. Chances are this is your problem. Speaking of, now that I think about it, my fuel pump doesn't prime either when i turn the ignition to the on position. I just never really gave it much thought since it starts up every time, due to the fuel pump rewire.
94 Talon 1.8L-SOLD
Old 10-02-2007, 10:10 PM
Testiklees
The fuel pump actually should only come on when the engine is cranking over. Having the key in the "on" position doesn't turn the pump on. This is for a 1G at least. Not sure about 2G's...
Tim
1990 Talon AWD
PTE SCM5031
Old 10-02-2007, 10:34 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
When I turn the key to the on position in my car I can hear the fuel pump prime. But I have a 2g
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-02-2007, 11:00 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
mine doesn't prime...but right now, mine wont start either because i have no fuel... but for the record, mine never did prime anyway
Old 10-03-2007, 09:51 AM
I'm used to the fuel pump priming with the key on because I mostly work on Fords and Chevys. I checked on both of my cars and neither the 1g nor the 2g would prime with the key on before startup. Go figure.
94 Talon 1.8L-SOLD
Old 10-03-2007, 10:33 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Mine runs for 1-2 seconds to prime the fuel lines.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
